AW: [NHL] Allgemeine News
Für mich 0,0 nachvollziehbar.
So überraschend die Verlängerung von Landeskog war, so überraschend ist Grubauers Wechsel nach Seattle nun. Nicht wirklich nachvollziehbar. Schade:(
Wer ist denn von den Goalies denn aktuell überhaupt noch auf dem Markt, also schon brauchbare. Oder Sakic muss irgendeinen Trade einfädeln. Bleibt ja fast nix anderes übrig. Da hat Colorado nun schon ein richtiges Problem.
Jetzt ist es Kuemper für einen ordentlichen Preis geworden ;).
Könnte aber funktionieren, ist ja kein so schlechter Goalie.
Kuemper ist erstmal ok. Aber der Preis dafür ist schon heftig. War aber fast klar nach Grubauers Abgang.
Zitat:
Zitat von
Long Term Injured Reserve (LTIR) - High Level Overview
To qualify for LTIR, a player must be expected to miss at least 10 NHL Games AND 24 days of the NHL seasonWhen a player is on LTIR, a team*may exceed the salary cap. Despite the common misconception, LTIR does not remove a Cap Hit from a team’s overall Cap Hit, it just potentially allows the team to exceed the salary cap.The amount that a team may exceed the salary cap due to LTIR is commonly referred to as the “LTIR Pool”If a team is cap compliant on opening day without using LTIR, or uses LTIR at any point during the season, the LTIR Pool is the Cap Hit of the LTIR player less the team’s cap space when the player goes on LTIR.* For example, if a player with a $4M Cap Hit goes on LTIR when the team has $100K of Cap Space, the LTIR pool is $3.9M ($4M-$0.1M). Because of this, team’s often make several roster moves right before a player goes on LTIR in order to be as close to the cap as possible, in order to maximize the LTIR PoolIf a team cannot be cap compliant on opening day without using LTIR, the LTIR Pool is the amount the team exceeds the Cap. For example, if a team is $3M over the Cap and places a player on LTIR with a $4M Cap Hit for the opening roster submission, the LTIR Pool is the $3M that the team exceeded the capWhile on LTIR, Cap Space is no longer accrued, meaning any portion of the LTIR pool not used cannot be used later.When a player comes off LTIR, the team’s annual cap hit for that day must be under the Cap
Auf deutsch und in eigenen Worten bitte einfach erklärt?
Ansonsten finde ich, dass sich Boston heute Nacht ordentlich verstärkt hat :huh:
Grubauer macht halt den Flower-Move :D Wer weiß, was er in Colorado bekommen hätte nach den letzten kürzlichen Verträgen.. von ihm aus kann ich den Trade schon nachvollziehen. Und von den Avs ebenso - mit Kuemper machen sie keinen riesen Rückschritt. Einzig, die Unwägbarkeiten für Grubauer, wie der Start in Seattle und die 1. Saison so läuft, birgt das eigentliche Risiko.
Na gut, dann jetzt ganz einfach formuliert und auf Deutsch.
Wenn Spieler länger ausfallen oder aufgrund ihrer Gesundheit nicht mehr spielen können, dann kommen sie auf die LTIR.
Dieses Gehalt kann dann genutzt werden um über den eigentlichen Salary Cap zu gehen.
Zitat:
Zitat von
Na gut, dann ganz einfach (was es eigentlich nicht ist).
Soweit wars mir klar
Zitat:
Ok, stimmt. War ja die Causa Kucherov erst vor Kurzem.
Was ich dann aber nicht verstehe, warum man so einen Spieler dann überhaupt verpflichtet? wenn sein Gehalt eh nicht gegen den Cap zählt..
Weil man dann wie gesagt mehr Cap zur Verfügung hat als die 81.5 Millionen.
Jein, das mit Seabrook ist eher vergleichbar mit der Causa Gaborik.
Zitat:
Ok... dann bitte Erklärung ;):o
Zitat:
Seabrook und Gaborik sind bzw. waren nicht mehr aktiv und sind nur wegen LTIR geholt worden.
Kucherov hingegen ist ja sowieso bei Tampa unter Vertrag und weiterhin aktiv.
Klar, für den Cap ist Seabrook/Kucherov gleich aber sportlich völlig unterschiedlich zu bewerten.
Auch das war mir durchaus klar. Deswegen hat mich ja die Erklärung des Punkers gewundert.
Hier wird die Long Term Injury Reserve ausführlich, aber trotzdem verständlich erklärt, auch die Besonderheiten in der Offseason und wieso es teilweise sinnvoll ist "Rentner" mit hohen Verträgen zu verpflichten:
https://www.capfriendly.com/ltir-faq
https://couchguysports.com/the-nhl-ltir-explained/
Gings dem Punker wirklich nur um den Unterschied Kucherov = aktiv, Gaborik = retired(mehr oder weniger zumindest)? Dachte, es stecke mehr dahinter... wenn nicht, dann isses natürlich klar
Danke!
Edit:
Soeben die Lektüre beendet.. ich glaub, ich habs verstanden.
-->Fazit:
Zitat:
To say that the NHL’s long-term injured reserve (LTIR) is a complicated system would be an understatement.
Mich würde jetzt nur noch interessieren, wie viele hier von den "Wissenden" das auch so wussten.. :-)
Hui, gings jetzt doch auch in englischer Sprache ;)
Natürlich gehts auf Englisch auch. Ich dachte mir, dass Thema wäre nicht soo komplex und könnte daher von einem Wissenden kurz in eigenen Sätzen zusammengefasst werden :rolleyes:
Lag ich wohl falsch.
Zitat:
Ich, aber so genau erst seit dem "Fall" Kucherov. Mitte April bin ich das erste Mal drüber gestolpert, als es hieß er trainiert normal und bleibt LTRI
Zitat:
Ist tatsächlich so komplex, dass ich's nach dem Lesen nochmal durch deepl gejagt habe. Aber auch der hat da so seine Schwierigkeiten bei der Übersetzung :-)
Ryan Reaves zu den Rangers. Könnte lustig werden gegen Washington nächste Saison 🤜🤛
