Was die Briten so schreiben...
Moderatoren: Penguin, J-F Labbeforever, CanadianOllie, chris9090, Rigo Kaka, Rigo Domenator
Hier werde ich die letzten Beiträge immer reinsetzen...
Ok, this week sees a bit more of a move towards the final line-up, and focussing more on the players who are likely to play a lot of the WC. There is a bit more that can be done and this is not yet the final team or lines. The lines are set to 65/55/45/35 to give more time to the players most likely to play, but still give some boost to back-ups who will feature in case of injuries (which may be more prevalant in the next engine).
In goal is Rivers, with Wilkins backing up (swap after 2 goals if losing). Atkinson is third choice at present. I will ask in a moment for opinions on which goalie the community feels is the long-term likely starter.
Defensive pairings are Smith-Murray, Jemson-Dyer, Small-McGiven and Stallard-Noone. The top-7 are clearly the top-7 and would give huge problems to work out who to drop if we played with 6. Noone is likely to play in the WC as he is catching very fast. Aston is the current #8 but will be overtaken by Noone. Bridges will overtake Marshall/Samways/Ward, none of whom are expected to play for the U20s. Ward has the Q/P to play but no EXP (I can't fit him in my team so he is listed to try to get the EXP up)
Centres are Bromwich-Burke-Eaton-Penrice-Hessenthaler-Lynas. Apart from Burke/Eaton who are close it is a fairly clear order although Hessethaler has a chance of challenging.
Wingers are relatively tough to choose, and are generally weaker than the other positions. They are hard to choose as there is a much wider range of Q/P and attributes all over the place, so it is very challenging to predict which players will be where by the WC start.
For now the pairings are Dobson-Ebbrell, Widdrington-Quinney, Hooper-Stein, Wise-Ryan. This week Wise and Stein have swapped over. The players missing out all have a chance of making the team, as they have better Q/P than a few in the team at present. Webber and Johns are new youth pulls that should make the squad if they can catch up the EXP difference, Forbes is a brilliant 18yo that may just have too far to catch up but could see some ice towards the end of the WC. Hignett has a slim chance of catching up the lower Q/P players as well. Richardson won't play.
PP/PK are the main area where we are still spreading players far more than we will later, rather than focussing on success. They are:
PP1: Quinney-Bromwich-Dobson-Stallard-Small
PP2: Widdrington-Burke-Ebbrell-McGiven-Dyer
PK1: Wise-Eaton-Murray-Smith
PK2: Widdrington-Bromwich-McGiven-Jemson
Noone and Stein are both on fourth line and no PP/PK so we can monitor precisely the difference between small minutes for U20 friendlies and big minutes in club friendlies + PP/PK as it may be that we are better off playing three lines and getting the fringe players into club friendlies.
As always, comments/suggestions welcomed, and the next post will be the goalie comparisons.
oK, community input please, not least as it involves my goalie so I would like an impartial decision.
Our 3 goalies have the following stats, I would like to know which one(s) should be playing in the friendlies to develop the best goalkeeping for the WC starting in about 6 weeks - not automatically which one is best now.
All listed as Goal-Speed-Pass-SC-EXP-Q/P
A: 37-46-8-22-4-90/71. Gaining EXP slightly under 2 per week.
B: 50-27-11-14-26-95/53. Gaining EXP at 2 per week.
C: 49-31-10-7-13-90/53. Gaining EXP at slightly over 1 per week, but no weak spot.
How should we play this, even if there is a clear favourite, there is the choice of do we focus exclusively on one goalie and risk injury or give the likely back-up some games just in case.
Thanks all, much appreciated.
EDIT: One final thing, After the youth pulls this week, I will be contacting all managers with a player in the squad to say how I feel their chances are and what training I would like the player to have. It would be rare for youth pulls much later than this week to make the squad due to the low-EXP, although not impossible if they have huge AI well proportioned.
ihre heutige Einstellung...
This week we have injuries to two starters, so I will switch to three lines. If we had a fully-fit squad I would probably have gone for four.
Ebbrell-Bromwich-Dobson-Murray-Jemson
Widdrington-Eaton-Quinney-Dyer-McGiven
Webber-Penrice-Hooper-Small-Stallard
To avoid excessive energy loss, all players feature on a special team line, and those who are on both PP and PK are on the second line of both.
PP1: Quinney-Bromwich-Dobson-Small-Stallard
PP2: Hooper-Eaton-Ebbrell-Dyer-McGiven
PK1: Webber-Penrice-Murray-Jemson
PK2: Widdrington-Eaton-Dyer-McGiven
Goalies are Rivers-Wilkins to swap after 2. Lines are 60 seconds for all lines, tactics are 10/0 every period as our defence is better than our forwards. As always, any questions please ask.
Das ist so geil, dass die nichtmal checken das der deutsche U20 Coach mitliest. Zu hart :-) :-)
An experience spreading line-up tonight, 4 lines, 60 seconds each, no-one on more than one special team line.
With Wilkins injured, the goalie tandem is Rivers/Atkinson, swapping after 2 goals as usual.
Lines are:
Ebbrell-Bromwich-Dobson-Murray-Smith
Widdrington-Eaton-Quinney-Dyer-Jemson
Webber-Burke-Hooper-Small-McGiven
Wise-Penrice-Johns-Stallard-Noone
PP1: Quinney-Bromwich-Dobson-Stallard-Noone
PP2: Hooper-Eaton-Ebbrell-Small-McGiven
PK1: Johns-Burke-Murray-Smith
PK2: Widdrington-Penrice-Dyer-Jemson
Interestingly, my original plan was to go with 4 lines at 60 seconds but have the PP/PK as I would in a WC match, I found that they virtually all split into either PP or PK, so went with the one spot each. Excepting injuries, the above 20 are the 20 that selection is likely to be from, Aston is the next best defender but not up to the top-8, Ryan and Stein are along with Wise for contention for the last winger spot if we play four lines.
Murray, despite being our best defender across the other attributes, may have to be dropped as he only has 1SC.
I'm not expecting a win tonight, I think the USA will take this more seriously than us given last season's results, it's all about experience levels and what we can learn from the match report.
so mal wieder zwei beiträge...
his is how the goalies looked 3 weeks ago.
Since then they have trained to:
A: 42/47/8/22/10 (+6AI +6EXP)
B: 50/34/11/14/30 (+7AI +4EXP)
C: 56/32/10/7/18 (+8AI +5EXP)
The conclusion before was unanimous for B starting all this season and likely next season, with most backing A as back-up. Is this still the community view? Does C have a chance at either role now?
I have my personal view, but as my goalie is involved I would like a community view as well please.
Exactly the same this week except Johns is injured so Stein comes in.
Two more things, one I would like to do a further goalie comparison, second, I intend to add a fourth goalie and replace the weakest 5 players in the squad with a line of 17yos at the end of this season. If there is such a thing as a meaningless game next season it makes sense to give the 17yos a taste of the action.
[LEFT] So das war die Einstellung beim letzten Spiel, es wird gegen uns wohl nicht wirklidh was geändert.
Everything as usual this week:
Goalies Rivers/Wilkins to swap after 2 if losing.
60 seconds for every line, so very much a friendly line up for experience spread not to win.
This is the top-22, although I'm not certain of the final 16 from them. A few of the players not in this 22 could play as injury cover but unless there is a training miracle or youth pull the competitive line up will come from this group of 22 in a normal 3-line WC game.
Marshall, Samways, Ward, Lynas, Hignett and Richardson will be dropped from the squad for a fourth goalie and a line of 17yos in the last week of this season.[/LEFT]
Bromley Ravens, League I.I hluraven
moderator
Posts : 388 Bild Posted 30/08/2008 08:23:44 AM Bild Bild Bild[url=http://javascript%3Cb%3E%3C/b%3E:confirmd%28%27delpost.php?quoteac=1&quoteno=36108&rub=4322&cat=4416&page=7&login=229663%27%29;]Bild[/url]Bild Same again except Stein in for Wise
I will be making the final changes to the squad on Saturday. This is essentially therefore the last call for players to be considered in the squad, so anyone you feel is worth a shot needs to be HA-mailed to me today or tomorrow. I would rather have lots to go through than none, so please send me even outside chances for the squad. 110 is the minimum AI, 10 the utter minimum EXP, but 130 is the minimum when you add the two together. I am sure some of these players are out there without my having found them.
I will be adding one 19yo goalie, leaving 4 goalies, 10 Defenders, 5 Centres and 10 Wingers in addition to a line of 17yos, (2D, 3F) and a sixth 17yo (another winger).
The players cut should come as no surprise as they were listed a few posts above (Marshall, Samways, Ward, Lynas, Hignett and Richardson), but I will need to cut one further player as well, I have not decided which yet.
I am still not 100% sure whether I will be playing 3 or 4 lines as a general rule, at the moment I am leaning towards 4 lines if everyone is fully fit, 3 lines is there are injuries, but this will be a game-by-game community input thing.
As ever, the target is qualify for the quarter finals and hope to avoid the eventual winners. Step 1 is obviously to qualify from the initial group, and we should do this, hopefully with enough points to help manage team spirit in the second group.
Posts : 400 Bild Posted 20/09/2008 11:17:54 AM Bild Bild Bild[url=http://javascript%3Cb%3E%3C/b%3E:confirmd%28%27delpost.php?quoteac=1&quoteno=36159&rub=4322&cat=4416&page=7&login=229663%27%29;]Bild[/url]Bild [LEFT] Ok, our first competitive game with this squad is against the Netherlands. The teams are fairly evenly balanced and this could go either way.
IMO the teams stack up as Germany top of the group, Sweden bottom, with today's game deciding 2nd/3rd but it is close between all 4.
We are playing this game on high as there is a good chance that we will both make it through to the next stage so the result could count double. We will play our next game against Sweden on medium, and then I will look at the standings before deciding how to play the final game against Germany. With any luck they will have won their first two games and will be taking it easy, but that is optimistic at this stage.
I am playing four lines, 65/55/45/35. There are a few reasons for this, the fourth line will have all those players who have less SC than ideally required and will play on medium aggression, the top lines get more of a rest, and Noone is a PP specialist defender who gets on the PP line but limited defensive role this way.
Tactics are spread evenly at 10 to attack each period, as in all the friendlies. Our defence/goalies are good enough, our wing/centre lacks goals big time. Just look at our friendly scores even with the attacking bias.
The goalie is Rivers, set to swap after conceding two, if we are losing. Back-up is Wilkins although Atkinson pushed him hard for the spot. All 4 goalies are within 10 points of form, making it pretty much a moot point, unfortunately 3 are dropping but at least #1 Rivers is rising.
Lines are:
Ebbrell-Bromwich-Dobson-Dyer-Smith - Hack n Slash
Widdrington-Burke-Quinney-McGiven-Jemson - Hack n Slash
Webber-Penrice-Hooper-Small-Murray - Hack n Slash
Wise-Eaton-Johns-Stallard-Noone - Medium
PP:Quinney-Bromwich-Dobson-Ebbrell-Noone. 4 forwards + Noone, and well balanced.
PK1: Murray-Burke-Dyer-Smith, 3 defenders+Burke
PK2: Johns-Small-McGiven-Jemson, 3 defenders+Small
Not 100% sure on the PK, I considered running with only 1 line, and considered either 2, 3 or 4 defenders, but settled for this. Our forwards are predominantly weak PKers.
The only potential changes to this set-up are Stein could come in for either Wise or Johns as fourth winger, we could play 3 lines, Eaton would rise up the lines if he got to 10SC, Atkinson could be back-up if his form was higher than Wilkins and there could be some changes to PP/PK. The core is pretty much set as is as far as I'm concerned but I will run the squad details past a few managers for a second opinion as I'm bound to have missed something.
As always, any comments or questions please ask here or HA-mail.[/LEFT]
interessante Rangehensweise...
chris9090
Beitrag von chris9090 »
Posts : 400 Bild Posted 20/09/2008 11:17:54 AM Bild Bild Bild[url=http://javascript%3cb%3e%3c/b%3E:confirmd%28%27delpost.php?quoteac=1&quoteno=36159&rub=4322&cat=4416&page=7&login=229663%27%29;]Bild[/url]Bild
[LEFT] I am playing four lines, 65/55/45/35. There are a few reasons for this, the fourth line will have all those players who have less SC than ideally required and will play on medium aggression, the top lines get more of a rest, and Noone is a PP specialist defender who gets on the PP line but limited defensive role this way.
[/LEFT]
Wenn er das gegen uns auch so macht, heißt das also 4 Reihen und in der vierten spielen bei uns Leute mit hoher SC, natürlich müssen wir dann auch die Eiszeiten anpassen, somit sollte die Vierte Reihe viele Strafen der Gegner ziehen oder?
A few tweaks but no major changes this week.
We will play on medium, it is definitely not worth playing on high as Sweden are favourites to not qualify, but playing on low would mean a pretty guaranteed loss and that is too dangerous.
Still on four lines (65/55/45/35) with the only change being Eaton and Penrice swapped, although this was a close call due to form. Quite a few players are under 50 form, not that there is any way to influence this, but we are not looking strong on this.
We have dropped the second PK line entirely, no change to the first PK line. The top 3 lines are playing on high aggression with the fourth on medium. If Johns (9) and Stallard (7) can get to 10SC we can play the fourth line on high as well, but I fear that Stallard won't get there at all and we don't really have an eighth defender who can step up to U20 level without him.
A win or draw guarantees progression to the next phase whatever the other results, a loss means that we would need a point in the last game to make sure of our progression.
Ich meine, sie unterschätzen die Schweden da ein klein wenig...
so jetzt kommen die interessanten Beiträge:
Another victory, again a touch fortunate. A great powerplay performance with 3 goals from 6 PPs, all Quinney, and another excellent goalkeeping performance (36 of 38 shots) give us the win, and guaranteed place in the next round. This disguises the fact that we were outplayed in each area. Every line lost its faceoff battle and aggression battle, and they had 10 more shots than us.
The faceoff thing is weird though, they won 21, we won 20, so it would be impossible for all 4 of our lines to have a less than 50% rating, but that is what is shown.
We now play Germany in what is a group game for the next stage. We are both through to the last 12, and the result next week will be taken forward to our group of 6, along with our win against the victors of the Netherlands v Sweden tie. Advice encouraged, but I would suggest we play on medium. Low seems too much like a surrender as we may need the points, but it seems too early to be playing on high.
As for other changes to the line-up, I don't really see any glaring holes or weaknesses, so I will probably stay with this set-up unless injuries alter things. As always, advice welcomed if you have any suggestions.
EDIT: Our next group will consist of GB, Germany, either Netherlands or Sweden, Denmark, Finland and either Romania or Slovenia.
Whichever of Netherlands/Sweden and Romania/Slovenia go through will start on zero points. Of the teams we haven't played yet, Finland are probably the best team out of all 6, Denmark will be tough, probably the same as Germany who are slightly better than us, and we really want Romania to best Slovenia, as Slovenia are actually very good whereas Romania would be the whipping boys.
After looking through this, unless Romania shock Slovenia, I can't see a likely victory in this, we probably need 3 points out of 4 games (including Germany) to go through, which is definitely doable but not easy. I'm beginning to consider going to high next week to try to get points on the board early as I would find it very unlikely for Germany to do this.
Bedeutet wir bekommen nächste Woche wohl 4 Reihen und hoch als Gegner. Jetzt können wir diskutieren. Er denkt eigentlich wie ich. Wenn man 4 Puntke mitnimmt ist man eigentlich schon fast im Viertelfinale. Sollten wir mit hoch und drei Reihen dagegen halten?! Bitter natürlich, wenn wir dann das Spiel verlieren sollten...
Beitrag von thomas »
Nächste Woche ist quasi bereits das 1.Spiel der Zwischenrunde. Und das will ich natürlich gewinnen. Im Vordergrund steht bei mir immer rechtzeitig zu Punkten zu kommen, die Teamstimmung kommt erst an 2. Stelle.
Ich will auf alle Fälle diesen Sieg haben. Wie taktisch genau gespielt wird hängt praktisch ausschließlich von der Form nächsten Sa ab.
CanadianOllie
Beitrag von CanadianOllie »
Ja Thomas da gebe ich dir recht, aber ich denke das ein bißchen Defensivtaktik uns nicht schaden würde.
CanadianOllie hat geschrieben:Ja Thomas da gebe ich dir recht, aber ich denke das ein bißchen Defensivtaktik uns nicht schaden würde.
Problem ist einfach, das bis auf 2 Verteidiger fast alle beschissene Form haben. Da half letzte Nacht nicht mal die Verteilung der Taktikpunkte auf die Defensive (denn dann dürfen wir keine drei bekommen). Also da haben wir momentan ganz klar unsere SChwächen. Ich hoff das bessert sich bis zum nächsten Samstag noch ein wenig mit der Form.
Das nächste Problem ist, das Pockel sich für 5 Tage abgemeldet hat und somit der nächste Defender sein wird, der im Formbereich 40 rumdümpelt. Langsam mach ich mir Sorgen. :cursing:
thomas hat geschrieben:Das nächste Problem ist, das Pockel sich für 5 Tage abgemeldet hat und somit der nächste Defender sein wird, der im Formbereich 40 rumdümpelt. Langsam mach ich mir Sorgen. :cursing:
Positiv ist aber auch, das 4 andere Verteidiger steigen! Vorallem Dreyer, Wilegalla und Habisreuthinger sind da sehr positiv. Ich hoff die steigen jetzt aber ne ganze Weile, um mal von 40 wegzukommen!
Bei den Stürmern könnte Kowalski und Hausmann sehr interessant werden.
Laß mich bloß mit dem Polacken in Ruhe. :-)
